jasonhc73
Cat herder, and dog toy tosser.
$250 Each. 8 total available.
Wichita Kansas.
I am going another route with my configuration.
In configuration and used regularly and safely daily.
I have 4 battery monitors with easy direct connect plug and play BMS cables that I made. All wiring on and in the battery is/are unmolested. I still have the OEM BMS that nobody knows how to use with them if you want them as well.
In 48V setups, I charge these to and float at 53.1V and disconnect at the inverter at 49.0V.
If you want to use them in 24V setups then divide by two.
The 4 "BMS" that I used all the MOSFETs died on me, made in china junk, but they are fine for monitors, and VERY light balancing, half amp each. All have Bluetooth connectivity and configuration.
All 8 are slightly more than 14 kWh of safe usable energy.
Call/Text - 3one6-37one-4224, or pm through the system.
Wichita Kansas.
