Until the OP responds we'll know for sure.
Here he says "It's time to replace the 12Kw (never really was) FLA system in my RV that I built 5 years ago. All I'm getting is 2Kw before the voltage is 12.1V. I used to be able to go 2-3 days using 1kw/day when there was no sun but now the system needs to be charged everyday with a generator."
1kw/ day is not that much at all and with FLA it's all about having the multiple day reserve to ride the storm out and not "having" to run the generator. I believe lfp can eliminate the need for multiple day reserve if one doesn't want to drop excessive amount of cash on batteries. The OP has a fair amount of solar and with the inverter/ charger he can charge off of the generator for an hour or two to give a "boost" to his SOC to hold over for a better solar day charge instead of the marathon charge cycles for dead lead. Using the lfp for long periods of partial SOC isn't going to hurt them like FLA as we can see/ know.
The purpose of the 800Ah (940Ah) FLA bank was to able to go 5-6 days and still be above +/-50% but in real life it was only 2-3 days.
Crown has a 2 year warranty so after a year of being at +/- 50% after using 2-3Kw I took 2 back to the dealer. They used a starting battery load tester and said the batteries are 100%. Since then I've installed a few more FLA brands and never had any meet the 20Ah load rating.
For the FLA to match the usable capacity of Lithium I'd need add 40% more capacity so the weight saving vs. Lithium would be closer to 400-500lbs.
With Lithium I won't have to check the BMS to see if the batteries are 100% because it doesn't matter. No more running the generator for hours and hours in float hoping to extend the life of the FLA.
