I want to run an A/C off my 1200 watt solar setup with 560 ah of batteries.
A 9000 btu 17 seer mini split a/c unit will use around 650-750 and up to 900 watts
A 12000 btu mini split uses an average of 900 with up to 1100.
If they are both inverter mini splits, wouldn't they use the same amount of power if set at the same temperature? The 12k one would be running slower but using the same watts.
Is my thinking off?
Is my thinking off?
