I can build a second array with similar size elsewhere on the land.
I went through the steps involved to be allowed grid feeding my surplus power.
Especially for winter times, when having 88 panels would also not be enough, especially without a good power storage I am dabbling with
I can install up to 5 of them on my main roof and a couple more elsewhere on my land.Cheap chinese horizontal wind turbine, an in depth exploration.
--- Begin edit Please do not reference to unproven products. A proven product should at least have an rpm vs some kind of output graph with warranties. for the building of a DIY alternator that actually works please see...diysolarforum.com
Then I think I am out of options in terms of power generation other than inventing a fusion reactor
Your graph proves my point about not generating enough. For instance, November last year generated 114kWh which is 3.8kWh per day. Even if you double that it's only 7.6kWh per day. That's nowhere near enough even for our consumption, yours will almost certainly be much higher than ours. Just like here you have 4 winter months of inadequate generation.
If you pursue this you will need to completely rebuild your system. At the moment your PV inverters are directly coupled to the grid. If you were to go for an AC coupled system like the Sunny Islands you cannot connect your existing inverters to the grid. The Sunny Island system controls the output of the PV inverters by changing the system frequency, you can't do that while grid connected. this mean that you will use different equipment for your grid connection, not the equipment for which you have permission. DC coupled systems will likely also require getting new connection permission.
I refer you to this concise explanation of why small wind turbines aren't worth it.
Small scale wind: Almost, but not entirely, worthless. Small scale wind you don't build yourself: Entirely worthless, unless you're selling the gizmos.
Literally everything is working against you. Wind power is proportional to swept area (so square of the diameter), and a cube factor of wind speed (double the wind speed, you get 8x the power). Small turbines have swept area working against them, and you'll find that their rated power comes at some speed you only get for dozens of hours a year, if that. Usually by the time you put them up, hanging in the trees/roofs/etc, you don't even get that speed for long. And with a cube factor working against you, they'll spend most of the year producing next to nothing, and being vibrating pains in the rear in the bargain.
On top of that, you need a lot more complexity in the system than you do for solar. If solar panels aren't having the energy pulled out, they just... sit there. So if the battery bank is full, or the grid is offline, a solar panel needs nothing added - just disconnect it from the inverters and it can hang there all year long, if you let it. Wind can't. You have to have a diversion load that can take the full output of the turbine, otherwise it will overspeed. You might be able to do some tricks with shorting the windings and trying to brake the blades that way, but what you've mostly done is use the coils as the blade brake, and that works... until you burn them up, and the turbine overspeeds and is on fire. So you need a diversion load. Plus, perhaps, a mechanical blade brake. It adds substantial cost to the project.
