Everyone should have a lantern but if your indoors you want a lamp.
I have a 157 princess made in 48. ( made in Canada up to 1970 so they are not that hard to find )
Its made from parts used in the early American 220 series.
This one like the one I have uses gasoline but there were kerosene versions......
Like the American 220 it uses the T44 gas generator, a very common part most sporting good shops have.
But if you swap the gas jet out for a #6 from a model 200 or 242 lantern now your jetted correctly for K1 and this is much safer to have in the house VS gasoline.
You will need a pre-heat cup for Kerosene.
The part you want can be had pretty easy from a Canadian 247 lantern...
Just google the parts you can build the kerosene parts...
These throw off a lot of heat.
It can pretty much help heat a room in winter.
When its cool my wife likes to sit in her Gazebo with the princess burning for light and some warmth.
I burn normal pump gas in it as intended...
Inside with pump gas its just fine too its designed to burn gasoline, but....
Do you want gasoline in the house?
Im not worried about it, but im not you..
Aladdin is still in business and they make a great lamp too.
Its not going to be quite as bright as a pressure lamp but its very safe and provides lots of light and warmth to a room
