John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
This is a pretty good example of an entry level inverter generator.
1700 watts * .25 rated load * 11.1 hours = 4717.5 watt hours
4s 300ah battery
300 amp hours * 3.2 nominal volts * 4 cells * .85 conversion factor = 3264 watt hours
~50 pounds
pros:
no noise
no maintenance
>5,000 hours service lifetime vs ~1000 hours service lifetime for generator
cons:
slightly less capacity
2 hours to re-charge to vs 10 minutes to refuel for generator
Champion 2000 Watt Inverter Generator Parallel Ready | Norwall
Norwall Price Match Promise on Champion 2000 Watt Inverter Generator. Ultra-Light. Ultra-Quiet Portable Inverter Generator for RVing, Camping, Backup
www.norwall.com
Gas Tank Size | 1.1 Gallons |
Run Time | 11.5 Hours at 25% Rated Load |
Weight | 39.0 ~50 pounds with fuel and oil |
4s 300ah battery
~50 pounds
pros:
no noise
no maintenance
cons:
