HI.
We have a trace SW4024.
1-One feature is a search mode where the inverter , instead of being on. is idling, looking for reasons to be on, and sends out a tiny search pulse looking for a load request (my own lingo sorry). When you switch on a light it knows and quickly inverts. This method can save power. Thats great but our sump pump has a micro circuit looking for power failures as it awaits its own chance to run free and pump water. This circuit is getting confused by the every 16 second search pulse from the inverter. I am thinking some kind of big capacitor could be used to store just enough energy in paralell with that sump processor to keep it "normal" between pulses. Ideas? We won't usually have that sump on the batteries but is should be "right" if/when needed.
2-same feature "search mode" the lowest search load it will trigger from is 20 watts. One or more rooms has less than that due to good led bulbs. those rooms won't turn on the inverter unless you add some load like switching on two rooms at first. Is there, can we i someone make a false load that dissappears in a second or two? Maybe even like those flasher buttons you can screw in under a light bulb base.... but just a load that opens up with a snap disk...
