I've had wind power since before solar panels were commonly available, over 40 years anyway, and solar also more recently. My current machine is about 17 years old and has performed like a champ, with ZERO maintenance. But the other day, I noticed the Windy Boy inverter (made by SMA) was indicating 0 watts, with a 15 mph wind, and the resistor load warm warm. This now discontinued and not supported turbine has a very elaborate "voltage clamp" system, needed in a grid tied turbine to keep it under control when the grid goes down. I opened, for the first time since the install, the clamp's control box, thinking maybe I'd be able to see something I could easily fix. Right, not going to happen, picture shows the inside! The heating resisitors/dump load are in a separate enclosure above.
I was able to ascertain that the problem lies not in the turbine, it's producing power, (AC, 3 wires) but it's all going to the dump load, not to the grid tied inverter. The inverter is 19 years old, as of now I have two options: 1. Buy a new inverter, meant for a PV system, as the Windy Boy inverter is no longer being produced, but there seems to be nothing specific to wind power about the inverter, it's specs match most common inverters marketed for PV systems. 2: Or, run the needed 6 conductor cabling (the number of wires leading from the control box to the dump load) over to the house from the shop where the control panel now is, mount the dump load in the house as a 2500 watt (max) air heater, a not inconsequential amount of BTU's for a small very well insulated home on a long windy winter night. During the warmer months the unit would be shut down via the control box's shutdown button.
A third option would be to sell the entire system, as my hydro and PV systems produce in excess of my annual power needs anyway, to someone who wants to play around with a 3 bladed 12' diamter, low speed, high quality, wind system. The unit is built along the lines of the old Jacobs turbines, big. heavy, with a lot of swept area, with a 2500 watt max output into the grid, while at the same time having excellent low wind performance. It's quiet also.
