A reset Battery Changes Ah rating
CorkyL
Searsmont, Maine
Hi Everyone - first time posting and forgive me for my ignorance:
I had a 1 yr old Kilovault HAB 7.5Kw (150Ah) Battery fail with under current reg. 0v(software). Since the company is out of business, I decied to try to fixt. I found 1 dead cell. recharged it to matching voltage and re-assembled the battery. I reset the BMS internal button and restarted it. first try didnt work- I bypassed the BMS and charged to whole battery to 57.0V. After resting it dropped to 56.2V. Restarted and the alarm went out and is holding a charge but registers only as 100Ah. How does that change? I have (3) more of these batteries. I have since added it back to the main bus. and voltage is staying at 54.1V.
You probably should cycle it from full to empty then let the unit recharge them itself. Most things like this will reset when they fully charge from near empty.
