A small UPS for what purpose?
At my home, we lose power for like 3 seconds about once or twice a week. Its not a big deal, except our desktop computers only take so much of it before one component or another decides to give up the ghost.
I pulled an APC UPS 750 Pro from someone's garbage. The battery was trash so I just threw it into the recycle bin and hooked up a large 12 volt marine deep cycle AGM battery to it.
It runs both of our desktop computers + two 27 inch monitors for about 2 hours.. Its been working for over 2 years flawlessly.. and I haven't had to replace a computer component once.
I like those APC UPS 750's too (I still have a few of them laying around). I have one where I took it apart, disabled the charger circuit on the main board, wired it up to 3 external Optima batteries (as I used an IOTA 55a charger to charge them separately), and I also put on a DC-DC regulated 12v power supply to run all the small devices like modem and routers with stable voltage off battery power.
I had also ran UPS Nut Tools (
https://networkupstools.org/docs/man/upsmon.html ) onto a rooted NAS to be a master, and when the battery bank would get down to 'LOW BATT' status on the UPS (had USB-to-serial cable connected between the NAS master and the APC UPS 750 ES), then it would shut down all the slaves (computers) and then shut itself down gracefully.
I like to integrate the safe shutdown strategy on my UPS solutions to gracefully unmount all filesystems to help avoid file corruption.
I have some old pics of it from around 2010 of it below. I don't run anything so fancy today though. Back then I ran a lot of lab stuff for personal training, but now work supplies me prettymuch any hardware I need at their site in the lab to learn about new stuff for my job on.
Today I just have a very simple setup with 2 NAS (one primary, one backup)...
Here's a couple of fun pics. APC 750 is the one on bottom left shelf in the rack, the IOTA charger is just to the right of that:
You can see my little black/red battery leads coming out of the UPS on the bottom right corner of it. I still have that modified UPS sitting around somewhere in the storage. That UPS I only had running one PC and two NAS's in that rack that I cared about, the rest of those servers were just for lab stuff so I didn't care if those lost power...
A few years ago, for my Stepdad, he wanted a backup power for his pellet stove (so it wouldn't smoke up his house when the fan/feeder would die on a power outage) so I wired him up an APC UPS 1500 VA (24v battery setup), where I hooked it up to 2 large external AGM 12v batteries in series (instead of the tiny internal batteries it had before). It would run his pellet stove for several hours on that.
You can always connect bigger batteries to them if you want, I just put jumper leads on them and run them outside the case or original battery tray of the unit. They will charge bigger batteries fine, it just takes a while longer to charge, which is why on the setup in the above pics, I installed the IOTA 55a charger so charging recovery would be faster than the APC UPS 750 ES could provide with the onboard charger.
