tetonmtnbiker
- Jun 9, 2020
- 27
Hello All,
I’ve been lurking for a while and am read to take the leap. I have a new imagine xls travel trailer with “solar prep” (10 gauge wire running from the roof).
i attached my wiring diagram (plagiarized from Will’s classic system) and have a couple of questions if someone would be willing to take a look.
1) is the 10 gauge wire in the solar prep sufficient for the current from the solar array as configured?
2) is the 300amp breaker the right size? (I used the chart from One of Will’s links, but I want to make sure I’m right here)
and, here is where it gets complicated... I want to use (if possible) the onboard power center in the new trailer. I am planning on installing a Go Power ATS that has a separate power out for the charger / controller In my power center. I am planning on running the main power out of the ATS into the main in the WFCO panel (wiring diagram also attached), but attaching the ATS’s Charger/converter line into the the wires labeled “from converter” in the WFCO. i believe that when I am on solar/battery power that line will not be activated and I won’t have the “batteries charging themselves loop”. I plan on attaching the WFCO posts labeled “white to battery negative” and “to converter positive” back to the battery bank. Also, I am planning on using the existing power wires That run to WFCO for both shore (that will now be coming out of the ATS for AC) and the DC side (currently from the cheap battery that came with the trailer (8 AWG)). finally, i think I may need something to interrupt the charge function of the WFCO when on shore power because I fear that unit cannot charge my lithium batteries safely (and solar should do it just fine when I’m on shoe anyway). As such I am thinking of adding a contactor to interrupt the line to the battery when it senses power coming out of the “to charger / converter” out of the ATS. That way the line is “broken“ to the battery when on shore, but the converter still is operational. But I have 4 questions.
1) will this plan even work (I’m afraid I may be reading the WFCO diagram incorrectly and have the wiring wrong back to the battery)
2) will the 8 AWG wire currently running from the the battery that came with the trailer be large enough t run to the DC side of the WFCO (total ~20 feet (that is shorter than current factory setup))?
3) do I need the contactor (or some other way) to stop the shore power from trying to charge the battery bank
4) am I missing anything else
BTW - I’ve really enjoyed geeking out on Wills videos and this forum. And the battery “bank” will actually be a fortune 4s2p single Battery with a BMS. Thanks in advance, you guys rock!
jeff
jeff
