I’m a newbie to solar, but not to DIY. I expect to be able to self install this entire setup, I’ve got the tools and skills (mostly.). I’ve spent the last two weeks watching all of Wills videos as well as dozens of others. I’ve got most of the basics.
Some background - I live in the Phoenix metro area. Home built in 1979 that’s fairly well insulated, 2000 sq ft, radiant barrier, attic fan with 4ton American Standard two stage heat pump. My equalizer SRP (local utility company) would be $250, winter this year averaged around $100 while summer is $250-$335. I’m a single dad who has my kids half of the time (14 and 11). When they’re not here I spend probably 90% of the day in one room and the nights in the MBR. I’m paying a lot to cool a home that’s mostly empty.
My goal is to become somewhat independent from grid power (for the inevitable zombie apocalypse of course) and to increase comfort (cooling) during summer without having to scream at the kids to close the door (I think every generation gets that, lol.) . I do not plan to be grid free, not for some time at least. I understand this project likely won’t save me any money for a decade or so. I’m not here for ROI. That’s fine. I understand what I’m paying for but I would like to maximize my purchases and setup for that end goal. Nothing is getting cheaper and I’m an idiot for waiting…..but here we go.
What I’d like to do is put 12k mini splits in the 3 rooms where we spend our time. Ideally the main 4ton unit would be cranked up to 85/90 during the day and then back on after 8PM (time of use plan.). When I’m home alone, I could very comfortably live with just two rooms being cooled (2x 12kton minis).
I did end up buying an Airspool 12k Hybrid unit for the family room (400 sq ft), more as a “get my feet wet” and now I’m hooked and see the potential solar seems to have finally cracked the AC issue. It’s up and running on 5 x 400 watt Alexus panels and I’m freezing, it’s great so far.
But after reading here and doing the math, I’m much better off buying an inverter, a few batteries, and panels but then using regular non hybrid minisplits for each room remaining. Those units can be had for as little as $400-$700 vs the $2k for the EG4 and Airspool Hybrids.,..that’s a huge difference. A difference that another poster pointed out would be much better spent on inverter, batteries and panels as the extra solar could be used to run other circuits when not being sent to the minisplits. Plus I could use batteries until they ran out.
So, my preliminary shopping list looks like this.
EG4-6000XP (got quote from Santan solar for $1529 OTD, local pickup). better deals elsewhere?
Minimum 200AH batteries according to what I can find (need help on this)
Solar panels to run it all (local to Santan so should be able to find good deals)
Wiring/boxes, etc
3 x 12k ton minisplits (non hybrids to run from inverter)
Assuming I have the correct number of panels, wiring, tools, batteries etc, am I missing any major components? The EG4-6000xp has the MPPT and SCC all in one, right?
I want to make sure I understand how the 6000XP works. The 6000xp will accept grid power input, I know that, but, does this mean that once my batteries are depleted (at min SOC) it will power whatever I have on it from the grid?
So if I have a mini split or two plugged into the inverter (6000xp) I should be able to run whatever I have plugged into (assuming I’m not over max withdrawal) from solar during day, then to batteries and then to grid? Meaning, the minisplits should be able to run 24/7 if I’ve set it up properly? This is my biggest concern/question.
As far as the batteries, what does 200AH of batteries look like price wise ( cheap wise)? And what voltage should those batteries be? Guessing 48 volt? Do the cheaper Amazon LiFePO4 batteries fit that bill? How many would I need as a minimum to get started? Cost? This is the one unknown cost I haven’t accounted for yet. I understand I can add them as I go, so I just want the minimum (or minimum recommended) to get me started,
Am I missing anything? Am I on the right path? I want to avoid nickel and diming it as these projects often go.
Wanted to thank a fellow local here on the forum who’s been especially helpful via DM. He’s the one who made me realize the hybrids aren’t necessarily the best way to go. (Smith AZ or something like that.)
Wiring/boxes, etc
