Are you saying you normally float at 55.1 or is this just about holding the voltage high enough and long enough to balance ?
By absorbing at 55.2 and waiting for EndAmps/Tailcurrent to be reached the batteries will be "full" but may still be somewhat out of balance internally, then by floating at just a slightly lower level. that allows the internal Active Balancer of the JK to level up the cells. I myself, allow for 0.005mv differential not the default 0.010. A-Typically, by the time all my packs (6x280AH) in my home system, switch to float, it may take as long as 15 more minutes to get them to 0.005 deviation - so really well balanced.
My Home system has 6 packs, some with original LF280's, then LF280N & LF280K-V3. One of these packs of a Frankenstein of LF280 & LF280N.
My installed systems are all consistent packs with identical cells.
Of note though, the LF280K V3 cells (dual hole) actually perform incredibly well (3 packs) and are always in lockstep with each other with the highest deviation between the packs never more than 0.005V. ALL packs have flexible busbars, either the Mesh Type or the Laminated Copper (dual hole). I documented all of this extensively elsewhere in here somewhere to show how it was done but I forget the thread it's in...
As I stated, I am in observer mode now. I only got into this thread to help our Greek Member out of a pickle... Even went to search for the manuals & docs for his inverter but their docs (what I found) do not get into custom settings for the battery profiles etc and to be honest, not into spending hours trying to find that info... I will only respond "if I feel like it" if/when I pop in.
@panos851 looking at your photo's is helpful. It appears the Battery Wires you are using are under sized for the potential amperage delivery.
Also a small point on Power Balance, the wires from the Inverter should be center of the busbars with the battery wires on each side.
Finally I recognize those busbars.... The ever infamous $40 for the pair E-Bay/Amazon specials... they can't even properly handle 100A (forget the label) and that plastic is terribly soft, especially when warm. Please for Gods Sake, get a pair of High Quality Busbars rated for 600A.
Unfortunately, I cannot (will not) suggest anything on Amazon or EBay as I am Canadian and part of the Boycott Everything USA movement.
The busbars I personally use & have deployed are from AMOMD which are Pure RED Copper link to manufacturer. They are on Amazon & Alibaba or look for Victron ones in Europe.
https://www.amomdmarine.com/Busbar-pl3583698.html
To readers, if you do not know what Red Copper is, it is true PURE Copper and these bars are Nickle Plated (not tinned or chromed).
