Hello,
I've inherited an existing 18kW Tesla solar install at my current property. It's grid tied with excess power sold to the utility. I have been wanting to add backup battery power but find the total cost of adding a Tesla powerwall beyond ludicrous. I've been trying to read up on how/if it's possible to add my own and there have been some great posts on the forum that have both been enlightening and slightly over my head. I'm wondering if my basic understanding is correct/feasible or if I'm way off in the weeds of this actually working.
My existing install seems pretty straight forward. Two sets of panel strings feed into two Tesla inverters with the AC combined in parallel and then fed into my utility panel and the grid. My proposed high level design is to inject an AC coupled inverter like an EG4 12000XP into the system just after the PV/AC disconnect switch and before the utility panel. My understanding is that the AC output from the Tesla inverter AC connects to the "Smart Load" of the EG4 configured for AC Coupling and then the normal "LOAD" output then connects to the utility panel/grid. In the future I can add additional ground mount solar capacity directly via the 12000XP.
Existing PV/grid configuration:
Proposed PV/grid configuration:
Thank you for any insight
