TymerTopCat
- Jan 17, 2021
- 1
I am in the process of building an Off-Grid Solar System, Utilities are too far away, and will never be connected:
*2 Sunny Island 6048 (120/240)
*1 7kW SunnyBoy Inverter
*24 310 Watt Solar Panels
* Minimal Battery Bank (Enough for 1 night)
* Auto Start Generator
Please, those will experience please correct any of my statements. I like AC-Coupling because it allows the use of daily excess power to run various high loads: 240 volt Planer/Jointer/Air Compressor/Water Pump/Dryer. As long as the sun is shining I should easily be able to use all of the higher loads mentioned *one* at a time. This is nice because none of those high loads would be forced through the battery (no recharging batteries) because the power came from the AC Excess Power. Am I correct here? Does anyone see any problems that I might be missing?
My questions are about when:
1. The batteries are fully charged.
2. Full sunshine (say 5000 watts of power are available but currently limited because of #1).
3. Now turn on a high load: Say I kick on a 240 volt planer (5Hp)?
What happens? Can the Sunny Island respond fast enough to deliver power to my Planer via the solar Panels?
Finally my Questions:
Q1: How well does the (FSPC) Frequency-Shift Power Control work? How fast can the Sunny Island increase or decrease Inverter output when a cloud blocks sunshine and then clears up again? Is it seconds? Minutes? See (17.5 below).
Q2: I have two different older Sunny Boy Inverters. SB7000TLUS-12 (Circa 2007) and a SB7000TLUS-22 (Newer Model). Will the Sunny Island work properly (FSPC) with one or both of these older inverters?
Q3: Is there another way to do this (AC Coupling only)? The Sunny Islands are a bit on the expensive side (new). I am aware of the used DC Solar inventory (mostly gone by now).
(From 17.5 Sunny Island Manual)
If Sunny Boy inverters are connected to the AC side of the off-grid system, the Sunny Island must be
able to limit their output power. This situation can occur when, e.g. the Sunny Island battery is fully
charged and the (solar) power available from the PV array exceeds the power required by the
connected loads.
To prevent the excess energy from overcharging the battery, the Sunny Island 4548-US / 6048-US
recognizes this situation and changes the frequency at the AC output. This frequency adjustment is
analyzed by the Sunny Boy. As soon as the power frequency increases
Tks.
connected loads.
Tks.
