thexformer
- Feb 25, 2021
- 6
Hi experts,
A new comer here. I have a little bit experience of building small solar system before but this time I am trying to build a bigger system with possibly multiple charge option.
Core components of my setup would be roughly as below:
1. MPPT solar charger 20A 12/24v
2. 8s Lifepo4 batteries of 105Ah
3. BMS of 100A rating
4. AC DC PWM power supply 48v 8.3A
5. Solar panels of 54V 300W
My question is, can I charge the battery if I feed the PWM power supply to MPPT controller? Provided that I will use the inputs separately ( won't use both solar and AC simultaneously) ?
I searched in this forum for a concrete answer but it seems it's a mixed answer. From those answers, my concern is that if MPPT charger tries to pull more current than the supply can provide? If that's the case, then may be the power supply will burn which makes a fire hazard. If someone has real life experience, then would appreciate if they can share the expressive or anyone can explain the logic that what should be impact hence caution or design change etc.
Thanks again in advance. I am already benefited from this forum hugely. And sorry if I have asked a duplicate question.
