waspie
While going over documentation again I see that whole home backup isn't possible in the grid-tie mode. That's fine, understandable, so now I am shifting possibly how I want to install this.
But a question comes to mind when installing it as passthrough. Does the outdoor meter+breaker box count as the AC disconnect if it's reconfigured?
Meaning I re-route the power coming out of the 200A breaker and send that to the inverter and then the output (load) wiring gets routed back to the indoor breaker box.
Does the pictured meter+breaker combo box become a code compliant solar ac disconnect?
and additionally, you can still run it as zero-export in this mode, correct?
