I am planning to connect my Growatt 3K-ES model to a Square D 70 amp with 2 space and 4 circuit sub panel/load center. I use EG$4 48V battery.
As you know the two spaces is for 2 independent live (hot) wires where as the output from the inverter come with just one hot wire. Do you think I can pigtail that one hot wire (from Inverter AC output) in the load center to give two hot wires so that I can used the 2 spaces and have 4 circuits?
Anyone does that before? The wire size is to be 8 AWG. Picture is for just for show only and not fully connected and I need to add the ground bar etc.
