Hello guys,
I am planing to extend my existing Setup with grid tied inverter (SDT G2) with AC hybrid inverter with 48V battery.
GoodWe as example below showed exact setup I need, but I would like to have 0W export in this setup.
Any idea if this would work ?
I believe the simplified ligic is based on power returned to Grid which is then used for AC charging of the battery .
But assuming I will deactivate export, how this suppoed to work ?
there would be an option to replace SDT G2 with EH or ES series only, but my grid setup does not allow it. Replacing the setup with HV inverter system is not usefull for me , since then my 48V battery setup will be lost.
thanks in advance
thanks in advance
