Absolutely!
I’d planned on getting a new charger but thought I could buy the wizard instead. So I’m back to getting a charger. An inverter is also on my list, but farther down. I don’t have a lot of inverter needs so I’d probably just buy one that will power my microwave for occasional use. It’s a 700w model so a 1000w or 1500w would probably be fine.
But please, I’m all ears!
Inverter/chargers combine and inverter, charger and automatic transfer switch.
Discrete inverters have gotten just about zero RnD since the the inverter/charger has eaten it's lunch.
Its even worse for RV converters, even the "lithium" converters are a joke.
The killer feature that inverter/chargers have is an embedded computer which allows for lots of features and granular configuration.
The most important for is the charge profile.
Typically you can choose the charge voltage, charge termination policy and float voltage.
The second most important bit is low voltage disconnect.
That means your inverter can stop inverting before the BMS has to disconnect the battery.
The BMS protects the battery and the inverter/charger protects the BMS.
Also the automatic transfer switch in an inverter/charger makes sure the ac current is synchronized before switching so that even your most sensitive loads won't even notice a thing.
With a olds style automatic transfer switches you will probably have to reset the clock on your microwave every time you switch power sources.
Finally discrete chargers are almost always high frequency which means their surge capacity is 2x for 20 milli seconds which is only important to the marketing department.
Most inverter/chargers are low frequency with a big honking iron transformer, these have surge capacity often rated in minutes.
Inverter/chargers cost more but they are better.
If you need 2 or more of inverter or charger or automatic transfer switch I suggest an inverter/charger is the way to go.
