Rich585
I am confused on wiring conventions.
Residential AC wiring has white wire neutral, black wire 120vac, bare copper for ground.
DC wiring has black wire negative, red for positive.
What I am confused is if you have a small solar system (dc) and have a 2000+watt inverter that allows you to run power to a small panel, what wiring convention is considered proper?
Would it not be confusing to have a black wire DC negative and AC “hot” in the same panel?
I am thinking towards wiring in a DIY camper or garage for example.
What is proper color coding or does it not matter as long as it is consistent?
thanks
thanks
