@Will Prowse
On your review of the AC200MAX, you said you were using the a battery charger off of the AC outputs on the AC200MAX to charge your 48v battery bank and then using it to charge the external battery packs (B230s). Wouldn't it be more efficient to just use the battery power blocks to charge the B230s directly from the AC200MAX with the overpaneling that you are using and skip the extra steps to the other battery bank?
Has anyone else done this with their AC200P?
