ericfx1984
- Oct 10, 2021
- 1,029
So I've been seeing that some people are using their BMS or their charge controller to activate a active balancer at a certain voltage ... Effectively leaving it off whenever it's below that voltage
So I have a couple different options that I'm hoping will work for this
I have the JBD 200 amp 16S BMS (I think it's actually seven ass through 21s?)
And then I have the MPP solar LV6548
Is there any programmable on off switch? I'm hoping that there's something that I can use that will complete a circuit when the voltage hits a certain voltage (maybe 54.4?)
I know my Victron 100/50 had a dry contact function that probably could have worked for this... I imagine that the MPP does... But I'm not seeing anything about it in the programming manual... And of course the JBD BMS is not super clear on that either
If neither of these items will work... Is there a balancer that won't cost an arm and a leg but also Not just sit there and run 24/7? Maybe some programability?
