I am updating the technology in my RV (switching from PWM to MPPT, Lead Acid to LiFePo4 and have a small problem, most of the existing cables have 3/8 inch lugs on them, and most of the new equipment has 8mm (5/16) female terminals with 8mm screws. My question is are there adapter studs, etc. that can convert the 8mm female terminals on the batteries, DC-DC MPPT charger, etc. to 3/8 (10mm) male studs or female terminals. I have found such adapters that go from 8mm to battery post, but not to 10mm, I have also found ones that do 10mm to 8mm, but they had female 8mm connections, not male that I would need to work with my existing 8mm female terminals.
thanks Ike
thanks Ike
