MachineYearning
I have an existing solar system in a small camper that uses a 100Ah Renogy LFP and 200w of solar. It runs everything fine, mostly. I also would like to use my Engel fridge in my car for occasional overnight trips.
It would be very useful if the 50Ah portable system I build for the car could also be used in the camper to add capacity during the shorter winter days.
tl;dr Can you use two different sized batteries of the same chemistry (LFP) from different manufacturers? Not happy with past Renogy interactions.
I got this idea when I saw several YouTubers building expansion packs for Bluetti, Ecoflow and the likes. Those cells aren’t matched for sure, but they also aren’t wired directly together either. Given they are capable of charging from multiple sources.
Thank you for your time.
