Hi all,
I have a 2000 Monterey 302 Cruiser with 2x gas motors, and 2x dual-purpose AGM batteries. As wired from the factory, it has no dedicated house battery bank, it relies on the dual-purpose batteries for engine start and house loads. It also has shore power (2x 30A) and a ProNautic 1220P battery charger (that charger is currently limited to 20A due to the existing wire and circuit breaker size - I could potentially upgrade it).
After a successful Lithium conversion of our camper earlier this year, I'd like to add lithium to the boat next year. I'm not looking for an inverter system on the boat, just sufficient power (probably 400Ah @ 12v) to stay away from the dock for several days without needing to run the motors to recharge, or needing to jump the batteries to get home (which happens a lot).
What I'm trying to figure out is how to add lithium to the system so both the house and starter batteries can charge from the motors and/or shore power, and also discharge the lithium through the existing wiring (as much as possible) to power the house loads (also assuming the lithium must be disconnected while the engines are starting). I've looked at various isolators and combiners, but I can't figure out a way to make it work without significant rewiring or creating charging loops.
Thanks for any suggestions!
