tldr; can I add a second 48 v battery bank(4 12v lead acid batteries) to my system easily? How can I mitigate any problems?
I have looked at previous threads using search and learned quite a bit but I still have a few questions and need some advice.
At the end of February 2022, I installed a solar system here on my off grid property. Here is my system:
12-240 used panels (2880 watts), panels installed with 4 banks of 3 in series.
48v 60 amp PowMr MPPT charge controller
48v 2500 watt Xijia inverter
4 12V Walmart Deep Cycle batteries in parallel
The system has performed very well for me over the past year. I run little to no load overnight and evening usage is supplemented with a 48V 15 amp Meanwell battery charger running from a Predator inverter generator(usually an hour or two during the winter). Basically when morning comes around(before sunrise), my batteries are usually between 50 and 51.4 volts.
My refrigerator and freezer are on timers. I have a 12 volt 180 ah LiFePO4 battery in my cabin that charges devices and run 12 volt appliances. I charge it up with a LifePo4 charger during the day. I also have a Bluetti EB3A that I charge up during the day from my main solar system.
I've thought about going with LiFePO4 for my main system but I really I can't afford it right now with many other things to do. Plus I get a lot of cold nights during the winter so I really don't want to have to deal with ruining my cells because I charged during the cold.
Being that I'm in Arizona and summer is coming. I'd like to increase my main system battery capacity. I survived last summer by running a generator way too long. I'm building a subsystem to take care of the cooling now so I'm really not needing it for that. I know I'm going to need to run my refrigerator and freezer longer, like all night. I'm also wanting to add a second freezer. Basically I probably need a bit more overnight power. But my budget is eternally stretched to breaking point. I know I can probably do it with what I have, but I know I'm stretching it.
What I would like to do is add a second battery bank of 4 12V Walmart deep cycle batteries. They will be the same as the ones I have installed, just one year newer? Is this going to be a problem? How I mitigate any potential problems? I've thought of getting an HA02 battery equalizer for each bank, are they helpful?
thanks in advance!
thanks in advance!
