dixonge
- Jun 18, 2021
- 190
So I have an existing array of 100W panels in 2S2P configuration. An additional couple of panels might be in my future. I would likely wire them in serial, but it is possible they will not be on the roof with the other panels, but will, instead, be portable on the ground. In this case I would be connecting them in the battery bay, not on the roof with the others.
Does this change the configuration and fusing requirements? Wouldn't this be a mismatch of volts/amps coming off the roof in comparison to the ground panels? Is this even doable? If so, is it recommended? Would it be better to just connect them through a separate SCC? If so, I have an additional PWM - can that be combined w/ my existing MPPT unit?
Apologies for so many questions all in one post....
