Hi everyone, I hope you can advise on adding an additional battery.
I currently have this simple setup right now, but stationary... EG4 3k inverter with an EG4 V1 48v LFP 100ah battery.
Its been running fine for over a year and I am looking to add another 48v LFP 100ah battery.
My ideal choice would be to add either the Vatrer or Eco-Worthy 48v LFP 100ah battery.
Anyone able advise which option would be best for a beginner?
I'm using the SmartESS app to monitor the inverter and as long as I can see the state of charge on the 2 batteries in parallel I am fine.
Are there any concern if I go with the Vatrer which has no comms?
Also do I need to balance the new battery before adding in parallel?
In this case, do I fully charge the EG4 battery to 100% SOC, then switch and fully charge the new battery to 100%?
Only then can I connect in parallel?
Is the process much simpler and safer if I stick with getting another EG4 48v 100ah battery instead?
Any advise is much appreciated.
48V 3kW Handtruck System
Dead Simple Solar Power System! 3,000W AC Output 1,800W AC Input 5,000W PV Input PV Voltage Range: 120-500V Scalable Easy to Build! This took me 25 minutes Can be mobile or stationary Turn off the...
www.mobile-solarpower.com
