I have asked some questions about this in another thread, but I thought I'd start a new one as my questions have changed considerably since I started the other thread
I just bought an off grid cabin this year. It has an existing solar system which isn't really meeting what I'd like for power. Currently there is a mish mash of panels that go into a PWM charge controller and then into 4 x 6v FLA batteries. They are wired to give 12V which then goes into a Samlex 12v to 120v 3000w inverter. There is also a number of 12v lighting circuits and a 12v water pump being run off the 12v feed and a 12v breaker.
I thought about completely ripping the old system out and just using the panels into a new inverter and adding more panels. I found out that would be difficult as it's PWM and most inverters are now MPPT charger.
I think I've decided on keeping the old system in place. I'd use it for the existing 12v wiring and I'd also use it as a backup in case there is ever a failure of my new system.
My initial thinking was to get an EG4 6000 inverter with a 3 pack of the EG4 48v server rack batteries and power them with a new batch of solar panels. I'd then have the output of this inverter go into a switch of some sort along with the output of the old inverter. That way if I ever had an issue with my new inverter I could just flip the switch over to my old inverter until I could rectify the problem.
Where I now am hitting an issue is that the EG4 inverter is split phase and my old inverter is just 120v single phase. That isn't ideal as I'd likely also need to change my panel and then if I did switch to the old inverter I'd only have power to half of the circuits in the new panel. I could likely work around that, but would prefer not to.
So now I'm wondering is there a way to get 120v single phase output out of one of the new EG4 6000 inverters? Alternatively, are there any good 120v single phase inverters still being offered that are still being supported and warrantied that would fit the bill? Is there another solution I'm not aware of that would work for me?
