Tasemu
- Dec 23, 2020
- 41
Hi all.
Up until recently I have been using a 280AH Lifepo4 bank on my narrow-boat with a Daly 250A BMS. Over a winter and a year or so, I noticed that I did not give the batteries time to balance and they had eventually gotten so out of balance that I felt the need to do another top balance. I took the opportunity to to purchase a new pre-made 200AH battery with an overkill bms from lifebatteries (UK) and installed it to take over the system while the top balance was being performed on the old bank.
Now I am wondering if it is possible to connect my old battery with the DalyBMS back into my system and have a total of 2 batteries supplying my system. These would be as follows:
1x LifePower 200AH Overkill BMS
1x DIY 280AH Daly BMS
In my head it feels that there should be no issue with these batteries working together, each behind their own BMS and both running through the same Victron Smart-Shunt to monitor the sum capacity.
Posting this to see if my thoughts are valid, or if there is any reason why this may be a bad idea. Thanks in advance for any and all advice!
