I have an existing bank of 4 x EG4 LifePower4 (V1) batteries. I'm considering adding a 5th. I'm concerned with keeping everything balanced so all batteries dis/charge at the same rate and to the same depth. I was very meticulous to make sure all batteries were "even" in regards to electrical wiring. All leads from the batteries are the same length, the left bar (+) is connected to the inverter from the top while the right (-) is from the bottom.
On the surface, V2's seem to be nothing but Pros over the V1's (better warranty, better cells, better BMS, shorter cabling internally) but I wonder if those differences lead to bank balancing issues when mixed with V1 batteries?
With all that in mind, should I get a V2 or a V1, and why?
