I'm looking at buying a Victron Phoenix 1200va 48v inverter to run 24/7, as my current 12KW Growatt inverters' idle consumption is quite high.
I want the Phoenix just for my fridge and TVs etc. and the idle consumption is incredibly low, but it doesn't have enough power to run my larger loads (Wood Planers, Saws, etc.)
My question is: Can I use my Growatt as simply a charge controller (The Growatts MPPT kicks on and charges the batteries regardless of it being "on" as an inverter.) and a Phoenix as my main 24/7 inverter, but switch the Growatt on when I'm working with larger equipment?
Would I just connect the two inverters to my batteries via Bus Bars?
