Yes. absolutely as 50ShadesOfDirt was mentioning, you can connect in DC input to the DC input of the Bluetti as long as it stays within the limits of the unit which I believe is 900W Max., VOC 10-145VDC, 15A. So you could easily add a 12-136v lipo battery bank connected to the solar input or a 12/24v battery to the car charging port. The unit will not care the power is coming from a battery and not solar/car.Is it possible to add a non-Bluetti Lifepo4 battery to the Bluetti AC200max?
I'm new to all this and have trouble wrapping my mind around it, but I wonder if I can hook 400 watts of solar (two 200-watt bifacials in serial...or parallel better?) to a solar charge controller feeding into a LiFePO4 battery to charge the battery, and at the same time hook the battery into the Bluetti (AC180) through the DC in port. I will use my Bluetti as an emergency backup for our freezer if the grid goes down, but while the grid is up, I'm plugging small appliances (air fryer, toaster, rice cooker, induction burner, dehydrator, etc.) as I use them (up to 1800 watts, of course) to try to cut down on our electricity use. The Bluetti now is hooked to my solar panels through one set of cables running through an RV-style gland into the house. I'd like, instead, to hook my Li Time 12.8V 100Ah (and more of them as I can get them) to the solar panels via that cable set, then simultaneously send the battery's collected power into the Bluetti for use with the appliances as the Bluetti runs down. I also have a Li Time AC battery charger that I tried plugging into the Bluetti AC output port to charge the battery, and that worked, so if that piece of equipment could be used in a setup to accomplish what I want, how would I do it? Mainly, I just need to know if it's in any way dangerous to do the solar to battery to Bluetti thing...Is there any update? I like to do the same thing.
Recently Lifepo4 battery prices significantly dropped as the Chinese battery companies are dumping their battery to the market.
I am thinking about "Solar - BMS - Lifepo4 - Bluetti".
But if Bluetti can charge LifePo4 through their proprietary external battery port, then I can try this "Solar - Bluetti - Lifepo4"
No, as long as the DC voltage that you are inputting into the PV port does not exceed the maximum specification then you can plug anything you want into it, regardless of where it's coming from.Mainly, I just need to know if it's in any way dangerous to do the solar to battery to Bluetti thing...
Thank you so much.No, as long as the DC voltage that you are inputting into the PV port does not exceed the maximum specification then you can plug anything you want into it, regardless of where it's coming from.
A bit late to this party but it is the Season. I was able to get a Renogy 60a MPPT Charge Controller 150v for around £100+ pounds, (normally £279 on their website). through black Friday deal. It takes a higher charge rate than my Bluetti AC200Max. I can charge my 2 12v 200ah LiFePo’s at around 800+w, then through the 20a load I can connect to my Bluetti PV. Only having 24v system I can get 245w in. If I had 48v system I can get over 600+w. Over the course of a day, I use on average between 100-150w per hour. Less stuff running at night, more during the day. I can run a full height A+++ fridge freezer, kettle, toaster, lights, fans, pumps, air conditioner, TV, laptop, iron, hairdryer and chargers for my tools. During the winter we can survive at least 2 days without solar (highly unlikely we would get no input however small and reducing some things i.e not needing fans or air con).I'm new to all this and have trouble wrapping my mind around it, but I wonder if I can hook 400 watts of solar (two 200-watt bifacials in serial...or parallel better?) to a solar charge controller feeding into a LiFePO4 battery to charge the battery, and at the same time hook the battery into the Bluetti (AC180) through the DC in port. I will use my Bluetti as an emergency backup for our freezer if the grid goes down, but while the grid is up, I'm plugging small appliances (air fryer, toaster, rice cooker, induction burner, dehydrator, etc.) as I use them (up to 1800 watts, of course) to try to cut down on our electricity use. The Bluetti now is hooked to my solar panels through one set of cables running through an RV-style gland into the house. I'd like, instead, to hook my Li Time 12.8V 100Ah (and more of them as I can get them) to the solar panels via that cable set, then simultaneously send the battery's collected power into the Bluetti for use with the appliances as the Bluetti runs down. I also have a Li Time AC battery charger that I tried plugging into the Bluetti AC output port to charge the battery, and that worked, so if that piece of equipment could be used in a setup to accomplish what I want, how would I do it? Mainly, I just need to know if it's in any way dangerous to do the solar to battery to Bluetti thing...
