Hi guys,
I've been reading through threads but cant find the answer I'm after.
I currently have 3x 50W monocrystalline panels connected in parallel to a 75/15 MPPT controller to my ~120Ah AGM battery. I also have a split charge relay between starter and leisure batteries. Recently while staying at a friends house I found myself a bit stuck when I accidentally left something on in the front cab overnight (late evening cocktails in the sun may bear some responsiblity). My starter battery was totally drained to about 2V. Luckily all I had to do was unplug my solar output from my mppt to the starter battery and wait 2 days for the starter to charge.
In order to do this I had to take apart my electric rig box to get to the cables to switch them over. I'm assuming this isn't best practice because the history of the battery in the mppt will get confused but I've been living on the road for years and it's the first time I've drained my starter accidentally. I'm thinking of adding in a way of switching from solar-output-to-leisure to solar-output-to-starter, if and when this happens again. My first thought was, just get a switch that will let me transfer the solar output from one battery to the other, maybe clear the history to avoid mppt confusions and then switch it back when the starter is charged enough. The alternative is to add a DC-DC charger between leisure and starter battery but I'm totally confused on the best way to do this.
I don't think I need a £150-200 dc-dc charger when a basic voltronic with a switch will probably be sufficient but Iknow very little about balancing, battery drains and the relationship between various power sources. I guess my question is, are any of these bad setups, is there a better way to go about it:
1) Add a votronic 3065 with an isolator switch between the leisure battery and the starter. If I need to charge my starter, flip the switch, let it charge and then disconnect it after.
2) Add a DC-DC charger between my leisure battery and my starter battery. Would I be better connecting the solar to the starter or leave it connected to leisure? Is it ok to leave the split charge relay in there?
3) Use a three position switch for the solar output from the mppt. It will stay on leisure most of the time but I can also switch it off or switch it to starter battery. I'll reset the mppt each time I have to use the switch but it's not going to be used more than once a year at most, so I'm sure the batteries and mppt won't stop being friends, right?
Any help or advice would be really appreciated!
All the best,
db123
All the best,
db123
