I have an existing 5 kW SolarEdge grid-tied system that’s connected via a line-side tap to my main panel.
From that main panel, I run a subpanel on a 60 A double-pole breaker that feeds selected household circuits. I have the Emporia Vue 2 and uses the Emporia EVSE to charge my car with excess solar when home.
I’d like to add my own 48 V battery bank and inverter/charger to achieve the following goals:
I’m aware my current SolarEdge inverter is not battery-enabled, so I assume I’ll need an AC-coupled solution (preferred) or replace the inverter with a battery-ready model.
The Battery Evo Walrus 4 looks close to what I need, but I don't see a way to vary charging based on excess solar on my main panel.
My main questions:
- Charge the battery from excess solar production during the day.
- Provide backup power to the subpanel during grid outages (automatic transfer preferred).
- Ideally, back feed to the main panel during peak rates (is this allowed by code?)
My main questions:
- Are there any inverters/charger systems that can dynamically adjust their AC charging/discharging based on line-side current probes, so they only charge from true excess generation?
- Are there any inverters that can back-feed through a breaker into the main panel to offset grid demand during on-peak times (while still being code-compliant)?
