WorldwideDave
I have Emporia Vue 3 in my subpanel now for 8 days. I love it. It is time to add it to the main panel if possible before I replace the panel. So I know I want to buy one with 16 CTs in case I replace my smaller panel with a new one with more places, but I do have a few questions about the installation.
Downstairs in the subpanel, I have the two large CTs connected to the incoming 100 AMP conductors, and the 16 others connected to the loads there.
In the main panel, I have 10 spots. It is a very old 100 Amp panel from 1960s we believe. CH brand.
2 spots (240V, double pole, 100 AMP) are in use for the main incoming conductors from the meter. So the conductors are always live - no separate breaker.
2 spots (240V, double pole, 100 AMP) are for the 100 AMP going to the downstairs subpanel
2 spots (240V, double pole, 50 AMP) are for the pool equipment 240 pump
1 spot (120V, single pole, 15 AMP) GFCI for pool light
1 spot (120V, single pole, 20 AMP) for indoor & outdoor lights
1 spot (120V, single pole, 20 AMP) for indoor receptacles
1 spot (120V, single pole, 20 AMP) for outdoor receptacles
I know I'll need the large CTs on the 2 spots coming in from the meter.
I think I can avoid putting another set of large CTs on the 100 AMPS going to the downstairs subpanel - is this correct?
I can use smaller CTs on the pool equipment, pool light, and remaining 20 AMP breakers.
So 2 large CTs and 6 small CTs is all I should need in that panel.
Am I correct?
I am concerned about wiring up the Emporia Vue. In the subpanel, I had a lot of new wires. I am afraid that in the main panel, I will have the old original wires from the 1930s or even 1960s, like I have seen throughout the property. Those wires do NOT like to be touched - their coating around them falls off with a strong breeze. I may get lucky and find out that it was rewired in the 1960s or 1970s. I've never had the cover off because I'm terrified due to the cover being painted/stuck in place most likely, and more importantly - no main breaker to kill power to the load center from the attached meter. I will likely pay electrician for that panel.
Other than wiring being old, anyone see any issues with the plan I proposed above? Any other suggestions?
Once installed, I will most likely post questions on how to set it up in the app - how to have 2 emporia vue 3 show up in the app under one combined house if possible.
Am I correct?
