All done! I added the fuse, installed my new AmpereTime 100A Lithium battery and wow!! What a big difference from my two old deep cycle lead acid batteries. With a low to medium load the voltage stays over 13 for a long time even with the panels turned off. With my (3) 100watt panels in series I am putting out around 68v and charging the battery at 15 amps. I also added a AiLi Qwork battery capacity meter to a custom battery box I installed inside my workshop. With the panels on and sun shining I can run my 8,000 BTU Midea window a/c with very little drop of voltage and charge level. I have a question on Lithium battery health. Unless I am in the shop running the a/c, the daily draw on the battery will be be very small. Should I turn off the panels after it reaches 100% charge and let it draw down to say 20% capacity over several days before recharging, or just leave the panels on full time so every day it maintains full charge? Which is better for Lithium longevity? Thanks!
