Hello,
Not sure which forum I should post this...
I am just getting into Home assistant, and, more specifically, ESP Home using ESP32 boards. It seems to me, one can make a WiFi-enabled sensor board to monitor each solar panel string. Measuring the voltage, current, and power over time should be fairly easy. My older inverters are very bad at WiFi monitoring!
The rub comes when you start to consider that measuring current using a clamp sensor is not very accurate, and it is expensive. I do not know if a shunt can be directly fit onto an ESP32 (differential amp with a lot of gain). Perhaps there are those folks out there who have already done this. Voltage can be done with a divider and a calibration pot. I have 11 different solar high voltage strings to monitor.
I found problems several months ago where the solar output had dropped significantly on a couple of the strings. It turns out that I had corrosion in several MC4 connectors, where I could not even get them apart! That corrosion caused a severe drop in power. Bought a bag of MC4 connectors, and cut off the bad ones, and installed new ones. Lubricated the 'O' rings with silicone grease this time. I bought some conductive grease to coat the metal conductors, but decided not to use it. Please comment if you have tried conductive grease to prevent corrosion ...
So, has anyone done this monitoring before? What sensors or components did you use? I design circuit boards, so making a bunch of these things would be straight forward.
Thanks in Advance (TIA)
GlenB K4KV
Moultrie, GA
GlenB K4KV
Moultrie, GA
