Hello,
I have an ongoing project I posted here.
We already have 4 x 400W panels in the rooftop of our warehouse that brings down up to 1600 Watts and 110V.
The inverter we are about to purchase (SUN-10K-SG02LP1-EU-AM3) has this specs for the PV string:
PV String Input Data
Max DC Input Power (W): 15000
Max DC Input Voltage (V): 500
Start-up Voltage (V): 125
MPPT Voltage Range (V): 150-425
Rated DC Input Voltage (V): 370
Max. Operating PV Input Current (A): 26+26+26
Max. Input Short-Circuit Current (A): 44+44+44
No. of MPP Trackers/No. of String Per MPP Tracker: 3/2+2+2
It says startup 125 but we only have 110V. Long story short… We are adding a few more panels.
The panel I have chosen to add to the string is a 580W panel with these specs:
Electrical parameters at standard test conditions (STC: AM=1.5, 1000W/m2, Cells Temperature 25°C):
Typical Type: 580W
Max Power (Pmax): 580W
Max Power voltage (Vmp): 42.56V
Max Power current (Imp): 13.63A
Open circuit voltage (Voc): 51.43V
Short circuit current (Isc): 14.34A
Module Efficiency: 22.44%
Max system voltage: DC 1500V (TUV, UL) / 1000V (CUL)
Maximum Series Fuse Rating: 25A
And the specs of the ecoflow panels are these (If I am not mistaking):
Rated Power 400W (±3%)
Open Circuit Voltage 37.10V (±3%)
Short Circuit Current 13.79A (±5%)
Maximum Operating Voltage 31.00V
Maximum Operating Current 12.90A
Maximum System Voltage 1500V
Maximum Fuse Current 25A
I wanted to ask if these panels can work together or if it’s going to blow up when connected in series.
PS: I am not going to install them myself. I will have a professional installer hired but I need to make the research here and have all the tools ready for him.
Thank you!
Typical Type: 580W
Thank you!
