Hi,
Was looking for other threads discussing this but could not find. Please point me if you see that I missed a relevant one.
My current setup (installed 3y ago):
Last year this setup produced 13035 kWh and met my expectations,
but did not meet my needs
Now to the grand Idea
These panels could also all have their optimizers if it is needed. Especially given that currently all panels have them.
In winter during the day we can have -15°C (but usually most panels are covered with snow).
Also October-March very few irradiance on NW roof
So would it be feasible to install such a parallel string on the same system. how do I size it? should panels be the same model?
Please share your thoughts.
as a side note. Besides more kWh I hope to have a bit better generation distribution through the day:
- Huawei SUN2000-12KTL-M2 (set up to accept 13.2 kW. but this is rarely reached)
- Modbus integration to Home Assistant (turning on additional load when have lots of solar)
- roof angle is around 30°
- 35 Panels Canadian Solar CS3L-375MS (13.125 kW total):
- 2 strings (17 and 18 panels).
- Each String connected to one MPPT (with one pair of DC cables)):
- Each panel has its own Huawei Optimiser.
- most face SE. 1 panel faces east'ish. 2 panels face west'ish
- In the image below you can see the pannels
- Red outline is for the NW roof
- Orange are chimneys
- Green is a Solar hot water heater (vacuum tubes)
- the NW facing roof has enough area to fit 25 panels.
- The inverter has a secondary connector on each MPPT for a parallel string.
- I have already a third pair of (unused) DC cables ran from inverter to the roof (had some other ideas
- Worked on some Online shade calculators and see that I could expect panels to perform at around 60% on this roof.
this parallel string option would be cheapest in my case.
one more could be changing the inverter to accept more strings (sell current inverter). But I can think of several problems.
- Should be Huawei because of all of the optimizers...
- Could only find 30KW Huawei inverter with more than 2 MPPT (which is also pricey).
- if different inverter manufacturer I would have to remove all the optimizers?
There is of course an option to put a standalone setup for the NW roof.
