binding_energy
I have a professionally installed system with one string of 10 panels on the main roof facing west with no shade problems + one panel on the gable facing south (that one has an optimizer fitted due to sometimes being shaded) . A second string consists of 7 panels on a south facing roof (a little distance from the main roof) all of which have optimisers fitted due to a complex shading pattern. System is rated at 7kW and works well, producing around 10kWh per day in the summer at my location.
I'd like to install a further set of panels on the east side of the main roof to catch the morning sun, before the west side kicks in, maybe another 8 or 10 panels.
I'm assuming these will have to be optimised so as not to compete with the west panels or the south panels.
Question
1) Do you think I would be better of connecting the new panels to string 1 (10 west +1 south) or to string 2 (7 south) - and why?
2) Would it be better to connect the new panels in series with the existing ones or in parallel, or even put pairs in parallel and the paid group in series? (data indicates that in the height of summer both strings generated around 300v max and the inverter has a max DC input of 550v)
My inverter only has two inputs so I can only have two strings at that point
I am quite competent to physically do the installation, just curious as to the most efficient way to connect them up.
Thank you for any help you can offer
Question
