Hi all, I am new here, so go easy on me.
I am considering the purchase of an RV with pre-installed solar system. It consist of 3 panels on roof for 640 watts, ( I don't know yet if in series or parallel), this is going into a Renogy 60 amp MPPT controller, charging 3-100 amp Renogy Lithium batteries connected in parallel.
I have some existing solar panels for 400 watts and am considering adding those independent of the panels on the roof as I would use the 400 watts as additional power positioned as needed to maximize the sun angle.
I believe that I would need another MPPT controller to do this. Is that correct? Since the voltages from each bank of panels input would be different.
On another problem.
Could I add a 100 amp Battleborn battery in parallel to the existing 3 Renogy 100 amp batteries? I did some searching on here and it seems as if it is possible.
Thank you
On another problem.
Thank you
