GXMnow
Solar Wizard
- Jul 17, 2020
- 2,710
The XW-Pro is mostly an inverter. That is what it wants to do. It can charge, but it needs to be forced to charge, it won't do it on it's own. When I read all about it online before buying one, I didn't believe this limitation. I figured it was some odd setup issue. But now that I have owned it for over 8 months, I can say without a doubt that the current software mine is running will never start a charge on it's own while it is on grid. There is a setting called "Recharge Volts" The battery voltage needs to fall below that for it to start a charge cycle. But here is the problem with that. The inverter stops inverting 0.5 volts ABOVE the recharge volts setting. In my system, I set it to 50.5 volts. My AC solar is back feeding through the unit, and I turn on grid sell and load shaving at 4PM. The XW-Pro takes over from the solar as the solar fall below the power needed to run my house and it provides all of the power for my backup loads panel, plus pushing 3 amps back to my main panel which not only runs the rest of my loads over there, it is actually exporting about 500 watts out to the grid. At 9pm I have it block the grid sell, but it still keeps running all my loads in the backup panel. Depending on how much the furnace runs, it will go to about 1 am when the battery bank drops to 51 volts, and then the inverter goes into standby mode. At this point, grid power runs the house. I have the charger blocked until 8 am when sun starts hitting my solar panels again, but nothing happens. The battery voltage is still above "Recharge Volts" and it just hangs there at 51 volts. Recharge was set at 50.5 so nothing happens. Now if the grid failed, it would kick back on and run do to "Low Battery Voltage Cutoff" which I have set down to 46 volts. But obviously it won't be charging without the grid. If it does run the battery down below the recharge volts setting, it will start a charge cycle when the grid returns. This was one idea I had, just have a controller take the unit off grid each night to run down the battery. Kind of a brute force kick start. The bad part is needing to operate a 60 amp contactor all the time.I don’t know anything yet about configuring the system, planning to order the PV panels the end of the month, batteries month after that.
So I expect to start it sometime in Summer 2021.
I have read GXMnow about some kind of problem with charging, but don’t understand it.
If I use my system “off grid”, I would expect there is some configuration that would cause the batteries to charge automatically, when the PV panels are receiving enough energy.
If I connect to the grid (no sell back) to obtain AC battery charging, I would expect the batteries to charge from the grid when there is no energy received by the PV panels.
But I’m just guessing here, no idea how the thing works / does not work due to software issues.
When the system is off grid, it can charge if you have AC coupled solar running into the output side of the inverter. If the solar makes more power that you are using, it will see the extra current on the output and start drawing that current to run as a charger into the batteries. I did do a short test and saw it charging at 600 watts, while my solar array was down to just making 1100 watts, and my backup loads panel was drawing the other 500 watts.
What I have been doing for now is just going into settings, and clicking on "Force Charge State (BULK)" each morning after the sun is up. I have found the Modbus command to do this, and I hope to get my PLC microcontroller to send this command for me each morning. I am hopeful that Schneider may someday fix this issue. It should be no problem to add that function in the gateway. It already has time settings for "Charge Block Start" and "Charge Block Stop". I am asking them to add a check box so when check block stop happens, you can select if you want to force it to start a bulk charge.
But the more I am looking into it, I think I am going to break down and install some DC coupled solar panels to do the battery charging. Each day, I am having to put about 7.3 kwh into the battery bank. I get over 5 sun hours most days. So I would need about 1,500 watts of solar panels. I have room for 6 panels, and I found some good deals on 305 - 370 watt panels. Best price per watt right now is on 355 watt units. 355 x 6 = 2,130 watts. 5 sun hours makes over 10 KWH. I could run the battery a bit lower each night and still get it topped up each day, and I would not be taking away from my grid tie solar, so I would be selling more power back to grid during the day, or having my grid tie help run my air conditioner more rather than charging the battery. My battery has a rated capacity of 360 AH at about 3.6 volts x 14 cells = about 18 KWH so using 10 KWH each evening would still leave a bit in reserve for a grid failure. And if the battery does run down during a long grid outage, the DC solar can charge the batteries and get me back running again.
