GXMnow
Solar Wizard
- Jul 17, 2020
- 3,506
I am also thinking that it might have something to do with the Victron charge controller. This issue has only happened since that was added. But the BougeRV controller also did keep pushing the voltage higher without an issue. The XW would do a very short absorb cycle and as soon as the voltage went above 56.7 volts, then no more current from the XW at all. Is the Victron CC putting out current/voltage spikes that might be confusing the voltage reading in the XW?? I could possibly se that, but the voltage readings in the XW on Insight Local all show the voltage climbing 0.3 volts above the set point and it was still cranking out nearly 30 amps. The Victron was also pushing 20 amps at the same time.Edit, any chance the Victon charge controller was still going and the increased voltage level was causing an issue for the XW?
I got a field job today, so I won't be here to monitor it today, but the weather forecast is calling for "partly cloudy" all day. Battery voltage at 6 am is down to 52.5 volts, (still a bit over 50%) it will drop a bit more before any sun comes out. The system would need to produce over 15 KWHs beyond the house draw to top it out. I'll check the graphs when I get home.
