This press is a great idea. I've been using a bending brake for mine, but they're not as sophisticated as your shape. Nicely done!I was thinking of designing and ordering a circuit board with fuses similar to the factory board. But, as the saying goes, "Don't let the perfect stand in the way of the good" or something similar. I should just solder wires right onto the tabs.
My 200/300 watt Weller "gun" type soldering iron was struggling with those tabs.
But, the TS100 does roughly 30 watts and did better.
I don't understand that...
I was looking at the bus bar. The factory bar is 0.8 mm x 46 mm
I ordered copper sheet at 1 mm
I bent up a bus bar by hand and wasn't super happy with how it came out.
Then, I remembered hearing about someone 3d printing a form to bend the metal over in a press.
It worked great, much better than my hand made one and even better than I expected!
Of course, then I measured and calculated the area and ampacity.
1 mm x 47 mm = 47 mm2 (complicated math, right at my level, lol)
Depending on the chart I use, that is something between 2 awg and 0 awg. Rated for 100-170 amps.
Considering that I am fused at 250 amps and may end up running on a single pack if I am working on the other.
I designed and started printing a second form to bend a bus bar inside the first.
While that was printing, cut off the un needed stud on the end of the 10s pack.
It is only 18 mm wide?!
0.8 mm * 18 mm = 14.4 mm2
That is just barely larger than 6 awg (13.3 mm2)
6 awg is rated for 75 amps.
I guess there is no point in printing and bending the second bus bar to stack inside the larger one...
That is interesting. With another 2 AWG wire, it sounds like you'll be fine, esp. because of your test adding a 8 AWG wire - the cells are extremely well balanced even now, though. Better than mine, which differ by .003 V regularly. I wonder why my cell group #4 was reading lower during charging rather than higher like yours. On discharging with ~200 watt load, my cell group #4 was increasingly lower and lower than the other cell groups, which stayed within ~.003 V of one another. Maybe it is a difference in the way we've configured our cell groups? My REC bms (unlike yours mine has passive balancing only) was pulling all other cells down to let the one cell try to catch up at the top end of the 10 amp charging phase. The bms was heating up almost to shut-off limit (55c) during this attempt. I figured this would stress it like crazy with multiple cycles, so right away thought of your description and installed a 2/0 cable that seems to have completley fixed the problem - I just ran a discharge test with 1500 W load, and everything looks good. Next test for me will be doubling my bus and testing without the cable.My plan is to eventually double the #2 cables (not 2/0) but for now I just added a #8 awg wire in parallel with the #2 awg cable, and it lowered the resistance enough that it is not a concern at my operating current. Here is a screen shot of my BMS operating at a 25 amp charge rate.
You can see that the two highest cells are still 10 and 11 due to the voltage drop from the cable instead of just a short buss bar. The resistance is causing the voltage to read higher while it is charging, and it reads lower while discharging. The difference is now less than 0.003 volts (3 millivolts) at 25 amps (the current reading on the BMS bounces from 22 to 27 due to the ripple current) that 3 mv is a difference of just 0.00012 ohms. The only reason this is any concern at all is so that the balancer does not erroneously start pulling from those cells while charging, and pushing back to those cells during discharge. I set the balancer to not try to balance until a cell is off by 0.006 volts. My maximum current is now about 80 amps during discharge. At this resistance, it might trigger a bit of balancing, but the times I pull that much is typically very short. When the microwave, vacuum, or hair dryer is running off the inverter. Most of the time it only 30 amps or less. Once I do double the cable with a second #2 awg, I think the total resistance will be vanishingly close to the buss bar.
I managed to get a picture of the sticker on my 8S battery module. I can't get to the 10S ones the way I have them bolted together, just no room.
It actually does say LiMM-C.F / LGE just like your sticker shows.
I could have sworn it said LiMNC oh well. All the text online says they are NMC cells.
The date code on this one is 1901 So yes, week 01 of 2019 makes sense.
My top line shows: Model Name: Vista 2.0 Cell Module Assembly
Next line Rated energy: 4.75 KWH this is the 8S again.
180 AH x 8 x 3.7 = 5.328 KWH in a perfect world. LG/Chevy seem to be rating them at 90%
