Adding slight tilt to roof mounted solar panels
Sterling9250
Portugal
I have an east facing roof that I want to put solar panels on. The roof is about 2° north facing. I’d like to add a slight tilt to a roof mounted system to at least zero out the north facing, but possibly add a few more degrees south facing. I’ll be using standard aluminum root mounts for clay tiles. Any help would be appreciated.
It is already used
Well I see your conundrum then, lol. My default response to tilting panels on anything except a flat roof is it's not worth it, and I think I would stick to that response. Just put as much panels as you can on the roof slanted as it is and you get what you get.
But, for the intrepid, I see that people have done it before.
Thank you
