Johnny Lightning
- Dec 24, 2019
- 34
Ok guys, here's the deal. I have a motorhome with a Magnum MS2000 inverter/charger and alternator charging. I want to add solar but I'm somewhat concerned about supplying too much amperage to my 2 100AH AGM batteries with a charging limit of .3C or 30 amps. I can see situations when I will be charging the batteries from all three sources at one time if I'm running the generator to cool the coach when I'm driving. I have a couple of question>
1. Does the C rate double when I have 2 batteries or not?
2. Do I run a risk of providing too much amperage to the batteries if all three systems are charging the batteries at the same time? The inverter/charger and the solar charge controller will have temperature sensor.
I know I should upgrade to lithium batteries but that's not in the cards right now, maybe in a year or two. Any help would be appreciated.
