GXMnow
Solar Wizard
- Jul 17, 2020
- 2,700
I spent about 3 hours out on the roof today.
My order of aluminum extrusions came in from McMaster Carr so I started to measure it out and next thing I knew, I have the 5 x 200 watt panels all mounted together on a nice frame. I'll try to get a few pictures tomorrow. I was a bit too busy cutting, drilling, and screwing to think about snapping pics. I also have the long rails assembled for the 10 x 100 watt panels. I am going to fasten them together to make the same basic shape as the 200 watt panels. I need to get 2 more pieces of 2"x2" angle to bridge together the smaller panels.
I also need to decide on my tilt angle and final heading before I bolt the mounts to the concrete blocks.
They are predicting another clear sunny day tomorrow. I might actually get it done if I can snag my brother to help. When you bolt together 1,000 watts of solar panels, it get's pretty heavy. I mounted the frame to the panels with the panels face down. I got them turned back over, but it was a struggle. Had there been a gust of wind, I am not sure I could have controlled that sail alone.
Today was about the perfect day for this work. We had decent sun, and it got into the 60's in the afternoon, so it was nice out on the roof. And as a bonus, I had no issue getting the battery fully charged even with disabling as much as 3/4 of my DC array. Check this out.
The XW completed it's charge cycle to 56.7 volts by 11:30 am. The DC panels pulled it up and went to it's Boost stage around 3 pm. When I saw it was down to just 400 watts, I turned the 200 watt panels upside down and it was still happy at 400 watts of float mode as I bolted up the framing. I even flipped the front row of the 100 watt panels to lay out where I need to drill the rails for those. It went back to MPPT mode when the XW started inverting. The weather is supposed to be nice like this again tomorrow, so I hope to finish the rails for the 100 watt panels as well. I only had to work a half day today and tomorrow, so I am being productive here.
And my Enphase system hit 24.1 KWHs also. That's just over 5 sun hours, not too bad at all for March 2nd. Last year today was just 22.9 KWHs. That rain storm got the panels nice and clean. Power for the whole array hit 3,800 watts, just a hair shy of clipping all 16 inverters for a full hour.
