LoveSailing
- Nov 15, 2020
- 4
Hello! I'm new to this forum, but not entirely new to solar. I have an old sailboat with limited solar real estate, and here are my current specs:
House batteries: Duracell Ultra AGM 105ah (2) in parallel
Panels: (2) Siemens 55watt 12v panels in parallel, connected to a Renogy Wanderer pwm controller
(1)HQST 100watt 12v panel, connected to a Victron Smart Charge 30amp MPPT controller
I just installed the Victron unit, and it's great, but I bought it with adding to the system in mind...
I ordered 2 new TP Solar 12v 50 watt flexible panels that I want to mount on my dodger. They should arrive today.
My question is, how should I connect my new panels to the Victron unit? The new and existing panels will not be close together and wiring will be tricky. Should I install a buss bar near the controller and wire the three panels in paralell? Or should I wire the 2 new panels together in series, then...?
Any thoughts and input would be greatly appreciated. Thanks!
